603,826 active members*
3,502 visitors online*
    Feb 2007
    19
    microtech cnc simulator
    Hi. Not sure if this is the correct forum for this....
    Does anyone use microtech cnc simulator? Heard about it and that it was 100% free, so of course checked it out. Having a problem with it and refuse to think that it wouldn't work in this program. I posted in the software forum, so far no reply. Not many people go there it seems.
    Anyways, now the problem. Drilling cycles. What it does is drill the first hole, then will just hover over the rest of the coordinates.
    Basically just checking if anyone here uses this software, and whats the deal with drilling cycles on it.
    Thanks in advance.
    Dec 2003
    24260
    Yes I have used it and have had the same result with a canned drilling cycle.
    I just assume now that if the first one is OK the rest will perform identicaly (apart from the position).
    Oddly enough, I have had the same thing happen with another free one I have tried?
    Al.
    Albert E.
    Feb 2007
    19
    Thanks, I'm going to email the guy and see what he says about fixing it. Should be really easy to fix. It drills the first one, so there is some kind of drilling function in the program, just needs to loop it for the rest of the coordinates until it sees a G80.
  1. free cnc simulator
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 03-27-2017, 08:01 PM
  2. CNC Simulator
    By dfedwards3915 in forum Education - Teachers and Students Hangout
    Last Post: 05-24-2007, 04:52 AM
  3. Emulator/simulator
    By rubianroaddog in forum Uncategorised CAM Discussion
    Last Post: 04-27-2007, 10:29 AM
  4. G-code simulator
    By Machinist16346 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-23-2007, 03:07 AM
  5. CNC Simulator
    By rhino in forum Uncategorised CAM Discussion
    Last Post: 11-01-2006, 08:49 AM
