603,826 active members*
3,109 visitors online*
Results 1 to 7 of 7
    Mar 2008
    1762
    Midi Sized Wood Lathe Addon
    A few of the first test cuts off the current project. Cuts are based on variations of Vectric Rotary Gadgets. All toolpaths, except for the noted hand coded file have been done with VCarve Pro.
    Usually I construct a special purpose machine that has specs above what an OEM would have. Not so in this case, as affordable NEMA 23 motors and an inexpensive 5 amp drive system was used. If you watch carefully you will notice that I am pushing the cuts about as fast as they can go.
    Also note that this is an attempt to quantify and compare speed, not quality. You should be aware that they are inversely proportional. This and some soon to come, will show as many ways to reduce rotary machining time where possible to allow time for the time consuming 3D portions of the cutting, if needed.
    Enjoy: https://youtu.be/WpLfE6kn0j4
    The machine is based on the Jet 122vs with stand. Fully supported linear rails and ballscrews. Porter Cable 1.75 hp router. 5 amp 4 channel drive. System control is currently designed for WinCNC as it has the most elegant control options, but this system (with DB25 connection) is close to plug and play with Mach, LinuxCNC, UCCNC, Planet and others. Optional DB37 to DB25 adapter required for ShopBot. Not all features are supported by all control systems. Complete assembled and tested systems available as are kits for standard and extended lengths.
    For more info email: GCnC411@gmail.com
    Gary Campbell CNC Technology & Training
    GCnC411 (at) gmail.com www.youtube.com/user/Islaww1/videos
    Mar 2008
    1762
    Re: Midi Sized Wood Lathe Addon
    Another Short video with instruction on hand coding files for the rotary axis. GCode file is on the CAMHeads forum in the Owners section.
    https://youtu.be/Ezdx2KVvFnU
    Mar 2008
    1762
    Here is another one showing 2 methods of cutting 3D profile on a rotary axis and then placing 2.5D vectors on that model and VCarving them:
    https://youtu.be/e9xkut4bm90
    Mar 2008
    1762
    Here is another option using Vectric products with a rotary axis. This rotary cutting option is one that has been in the works for a while. I am just getting to the finishing touches on the post processor trickery.
    Like the previous post, assuming an import of a 3D model, this can be cut using VCarve Pro. It is a simple 2D profile "On Vector" with the toolpath applied to the 3D model.
    Enjoy!
    https://youtu.be/24nSYX67Zik
    Mar 2008
    1762
    Mar 2008
    1762
    This machine is now available.
    email: GCnC411@gmail.com for more info
    Mar 2008
    1762
    Machine has Been sold
  1. Engraving Laser Addon Kit?
    By ducati955 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-16-2016, 12:27 AM
  2. ShumaTech Tach Addon Help
    By dneisler in forum CNC Machine Related Electronics
    Last Post: 10-22-2007, 07:02 PM
  3. Macro or Addon for ATC
    By steelhead1 in forum Mach Mill
    Last Post: 03-11-2006, 09:27 PM
  4. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-24-2006, 03:36 AM
  5. CAM addon
    By georgebarr in forum Autodesk
    Last Post: 06-01-2003, 06:33 AM
