603,864 active members*
5,123 visitors online*
    Jun 2005
    8
    Mighty comet parameters VMC-750 needed/Spindle problem
    Hi all,
    Does anyone have Mighty comet parameters VMC-750P. Would like main parameters and Spindle drive parameters if possible or even a close mighty control with Mitsubishi M320.
    Here is the problem. I reloaded parameters from some sheets we had. However when commanding spindle orient it does not go. Or commanding RPM it goes at the RPM that is designated in the gearshift parameter speed. The machine does not look like it has gear shift only belt drive to motor. So I think the Spindle internal drive parameters or mitsubishi parameters are messed up. The parameters were lost so hopefully its only in the mitsubishi side of things.
    Mitsubishi was no help and said that I would have to get from builder but they were no help at this time and they are checking into it.
    www.machinetoolhelp.com
    Sep 2010
    I have an older Comet CNC SN # 89049 that lost the machine parameters and options. Can someone help me get them?
    Anatol Service
  1. Mighty Comet/Viper 1000 - communication
    By czech in forum CNC Machining Centers
    Last Post: 07-27-2016, 05:44 PM
  2. T1 parameters NEEDED!
    By carbidecraters in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-02-2015, 01:35 PM
  3. Setting up Mighty Comet 1000 VMC
    By rogerindigo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-31-2014, 02:31 PM
  4. MIGHTY COMET MIDAS 320 CONTROLL
    By joshuasalens in forum DNC Problems and Solutions
    Last Post: 07-30-2009, 01:18 AM
  5. Mighty Comet with Meldas M0
    By Bert10 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2008, 11:35 PM
