588,014 active members*
6,345 visitors online*
    Jun 2008
    Hello,
    I have a problem with Mikron WF 21 D with controller TNC415.
    The centralized lubrication starts up every couple of seconds and the oil spills out.
    My question is: is there a machine parameter menu in this controller?
    How can I access it and which parameter should I change in order to increase the lube interval?
    Regards, Robin
    Hello Robin
    It’s strange that the centralized lubrication suddenly starts up with such short intervals.
    Have you already checked whether a lube able is leaky or broken?
    Maybe the system has a pressure sensor that starts the lubrication when there’s no pressure.
    Mit freundlichen Gr
