Originally Posted by
m1_machine
Hi Tim,
Thanks for the info. One of the things I noticed about Enco is that the Chinese made stuff is not cleaned before assembly. I bought a drill and as soon as I turned it on I noticed metal grinds dropping out of the spindle area. I disassembled the head and found it was loaded with the chips from when it was manufactured. You would think they could at least try to get the crud out before assembly. Next I purchased a 9x42 mill. This time I disassembled the head and removed the table before I ran the machine for the first time. As before the machine was full of machining chips. Once I cleaned it out and reassembled things, it worked well. What bearings did you go with? Were they the same size and type as the originals? It sounds like I may go with the same bearings you are using now.
Thanks,
Steve
