603,783 active members*
2,596 visitors online*
IndustryArena Forum > Employment Opportunity / RFQ (Request for Quote). > RFQ (Request for Quote) > North America RFQ's > [Mill] Mild Steel 3"x0.80x0.60 part = 4 pieces for proto RFQ by 2/13/20
Results 1 to 5 of 5
    Apr 2008
    80
    I used to be on this board quite a bit when I had my Haas TM1. Great board. I did put this job up on MFQ.com but this is ideal small job for the home guy with a brideport.
    I am looking for 4 part counts for proto. Just mild steel the outside edges can be mill scale.
    Need RFQ by 2/13/20
    Need finished parts 3/6/20 Shipping to Newberg, OR 97132
    Mark
    2005 Haas TM-1, 4th HRT160 - OneCNC XR4 Pro w/4th - Alibre Design Expert
    Metal-tech 4x4 - www.metaltech4x4.com
    Jun 2005
    95
    Re: [Mill] Mild Steel 3"x0.80x0.60 part = 4 pieces for proto RFQ by 2/13/20
    File appears to be corrupt. Sent PM
    Sent from my SM-J737R4 using Tapatalk
    Jun 2005
    95
    Remove (01) from the file name.
    Feb 2020
    3
    Hi Mark,
    We can manufacture this type of cnc turning job with 10 micron accuracy and 0.4 ra value surface finish.
    You can visit our website www.credexin.com for more our cnc products.
    Best regards,
    Dhaval B. Goti
    Feb 2020
    3
    Quote Originally Posted by helocat View Post
    Need RFQ by 2/13/20
    Mark
    We are Indian CNC components mnufacturer with 10 micron accuracy and 0.4 Ra value surface finish.
    Best regards,
    Dhaval B. Goti
    Sent from my Redmi Note 7 Pro using Tapatalk
  1. Replies: 2
    Last Post: 11-19-2013, 09:03 PM
  2. mild steel panels needed: 28" x 18" x 0.125" and 13.75 x 23.625 x 14ga
    By torinwalker in forum Employment Opportunity
    Last Post: 01-10-2011, 07:48 PM
  3. 1" mild steel milling
    By LarryRichardson in forum Employment Opportunity
    Last Post: 09-29-2010, 01:31 PM
  4. Cutting 1" Mild Steel
    By 3DSteve in forum Waterjet General Topics
    Last Post: 06-14-2007, 10:58 AM
  5. RFQ - on 1/2" mild steel plate
    By BullCreek in forum Employment Opportunity
    Last Post: 07-11-2006, 12:31 AM
