603,383 active members*
3,393 visitors online*
Results 1 to 5 of 5
    Feb 2008
    23
    Mill/Turn Programming
    Hi all!
    I do a lot of Mill/Turn programming and i routinely program using all three planes in the same program.
    The problem is I need a Mill/Turn config so I can plot from start to finish.
    Right now I devide my program up into seperate lathe and mill portions and then join them together after they are finished. That gets me through most of the time.
    Sometimes when I am programming say... NPT threads in G19 using a incremental style then that will not run in a mill config it seems because of all the W's and V's.
    Does anybody else out there have trouble with this? What are you doing to get around it?
    Thanks, Mike
    Feb 2008
    23
    One thing did I did just notice that I had not before; if I click my way through all of the warnings when I hit the milling portion of my program while running a lathe configuration, it does actually plot!
    Jan 2006
    2985
    Maybe you can set it up to ignore certain warnings so it will plot without all the clicking?
    Matt
    Feb 2008
    23
    I have switched from clicking each warning to just holding down the enter button until the warnings pass. Works a lot better!
    I'm not sure if there are enough settings to eliminate the errors; most of the errors are arc and plane errors.
    I am happy now anyway, I did not realize that my tool path was plotting even though there were warnings.
    Feb 2008
    23
    I saved a screen shot because I thought it was cool to have the NPT thread milling plotted in a lathe config. I go to metal later this week!
  1. Swiss turn programming
    By Rivet head in forum CamWorks
    Last Post: 07-12-2016, 02:23 AM
  2. MachStdMill Turn and Mill-Turn Announcement
    By mvcalypso in forum Screen Layouts, Post Processors & Misc
    Last Post: 11-16-2012, 03:38 PM
  3. Announcement: MachStdMill Turn and Mill-Turn
    By mvcalypso in forum News Announcements
    Last Post: 04-12-2012, 07:59 PM
  4. How is OneCNC for mill/turn programming?
    By Dan B in forum OneCNC
    Last Post: 05-18-2011, 12:23 PM
  5. Mulitplex-Dual turn programming
    By bl409 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-21-2009, 07:23 PM
