587,221 active members*
2,987 visitors online*
Thread: Mill Turning
    Mar 2006
    9
    Mill Turning
    I want to do some Mill Turning on a Taig as I need to do some turning but not enough to justify buying a lathe.
    I need to buy a rotary table and chuck but do most CAM programmes support this? (I take it that Mach3 just processes G code so doesn't care.) The files are coming from AutoCAD.
    Cheers.
    Jan 2009
    29
    The cheapest solution I have found for CAM that supports a rotary 4th axis is Deskproto. It's around $1200 and can do 3D objects like a bust or a perfume bottle etc.
    Cut 3D and Meshcam are more affordable but they dont do a rotary 4th axis, only top, bottom, left and right in 90 degree steps.
    Mar 2006
    9
    Quote Originally Posted by daanmuller View Post
    Many thanks.
  1. MBO: turning in the mill
    By X2cnc in forum Benchtop Machines
    Last Post: 04-26-2009, 06:20 PM
  2. Should I get a mill or a lathe? (Turning with a mill?)
    By JMcDonald in forum Uncategorised MetalWorking Machines
    Last Post: 11-03-2008, 05:02 AM
  3. Turning possibilities on a mill??
    By Aeromech6425 in forum Uncategorised MetalWorking Machines
    Last Post: 08-13-2008, 03:50 AM
  4. Mill-Turning on the Integrex
    By Integrexman in forum Videos
    Last Post: 06-07-2008, 05:13 AM
  5. what is the possibility of turning on mill
    By rkremser in forum Benchtop Machines
    Last Post: 12-11-2007, 05:30 PM
