Re: Milli a new composite mill kit
Originally Posted by
peteeng
Hi Pippin - What are you looking for and I'll see if its out there? Are you concerned CSA and UHPC are not equivalent? The German makers of UHPC machines must be very confident in their product? There must be doubts about EG as well as DIYers don't post cure, use all sorts of epoxy based on cost not performance. The epoxy guys do not produce a specific epoxy for the purpose etc etc. We assume "epoxy" is stable but its probably not, it being a plastic etc.... ??? Peter
Peter,
There is a lot of research and experience with epoxy granite as machine frames. I agree that "epoxy granite" is not all the same and should not be regarded as all the same - depends on mix, epoxy, how it was done etc. But the research is pretty consistent that damping is good, stiffness is 20-30 etc.
Apart from marketing from Durcrete (UHPC) I haven't found much objective research on UHPC or CSA machine tools. In particular CSA.
On paper the CSA manufacturer specs look good. It would be nice to see more paper showing no shrinkage after 180 days, vibration damping in machine tool structure etc...
(Maybe it is because I work in an industry where research and science are very important, but because biology is so complex, results often do not follow first principles / expected outcomes and everything must actually be tested to prove the outcome is as expected).
- - - Updated - - -
peteeng
Nice find.
They have a moving table version that looks quite similar to what I have envisaged for my mill. Except I would not have 5 Z rails and 2 Y ballscrews...
