Hi peteeng / ardenum2
Hello everyone
I'm sorry, but my English is not good and I haven't learned how to upload photos on the forum.
If you fill the inside of the steel plate with epoxy material, their expansion coefficient is inconsistent, and there will be many problems later.The best way is to use special concrete, but it costs three times more than epoxy.Few customers require special cement to be filled inside the steel plate, because the price is too high, the process flow is complicated, and it is not easy to complete with high precision.
Due to the customer's confidentiality requirements, specific photos cannot be provided.
Segmented steel plates,Embedded steel plate,Machining on steel plates, machining accuracy will be easier.The machining accuracy can reach 0.008mm/m.Of course, good processing equipment is needed - grinding machines or milling machine.
The price is definitely cheap,Because the processing volume of cast iron is too large, while the processing volume of mineral castings is small.
The specific processing cost still depends on the drawings.
