588,500 active members*
5,119 visitors online*
Thread: Milling 7075
Results 1 to 5 of 5
    Milling 7075
    I've done a lot of work with 6061 and a little work with 2000 series aluminum before, but I was wondering if there's anything I need to watch out for while milling 7075? Or should it be about the same as 6061?
    Apr 2003
    17
    If it is in a finished condition, say T76 it cuts easier then 6061 because it is much harder and will not gum up your cutters as bad. If it is annealed then that is a whole different story on milling it.
    Let me know if you have anymore questions.
    Material says 7075-T6 on it. So that means it should be a bit easier to machine than 6061-T6?
    Also another quick question.
    I need to mill a 0.57" deep 0.41" wide slot 1.66" deep inside of a part with a 3/8" end mill (for use on the 7075-T6 aluminum mentioned above). Would I be fine with a high helix (aluminum cutting) 2 flute HSS long end mill, or should I go with carbide for added rigidity? I plan on doing the machining on a full size manual mill, not my cnc benchtop.
    Jul 2004
    374
    A carbide endmill is definately a better choice considering your required flute length. I would also make it a 3 flute. The extra flute will give it a little thicker cross section for rigidity, and there will still be enough clearance between the flutes for chips.
