SO i've got some 6061 3/8" x 3 1/2" x 9 1/4" aluminum and I need to make it flat and relatively parrallel to each side. Now My Kurt vice has a 6" width capacity as I have a permanent stop block on one end for aligning parts. So that mean 3 1/4" is hanging off one side of the vice. I decided to just make a large jig out of 3 1/2" x 2" x 10" aluminum block. I will mill this flat and parallel and then use it as my jig to CNC machine the rest of the 3/8" flat bar. The problem is how do I get one side flat first, becasue if I bolt this to the jig first it will pull the bow out of it, but then it'll come back the minute I take it off the jig? I can't mill it flat with out the jig or it will vibrate and bounce as the cutter is moving over it, already tried it today with some wood as a brace on the other end.
Any suggestions?
