Hello
I’m searching for a milling cutter to rough on Roeders RXP500.
Material is tool steel + hardened steel.
Thanks in advance
Greetings herbstl
Hello
Thanks in advance
Greetings herbstl
Hi
It would be nice to have more information. We use Guehring HM. They are not bad.
Regards, Uwe
Good morning…
Is the company Aura now a tool partner of Roeders?
Just ask Roeders or Aura. They have very good tools – especially for hard machining.
"Diese Ausrufezeichen, hast du die bemerkt? Fünf? Ein sicheres Zeichen dafür, daß jemand die Unterhose auf dem Kopf trägt."<br /><br />Terry Pratchett
Hello
I heard about Mitsubishi VCHRFB, but they’re expensive.
Greetings herbstl
I would advice Hitachi EPP / ETM.
<span style='color:blue'><span style='font-family:Courier'><span style='font-size:14pt;line-height:100%'>Entt
Doesn’t every tool distributor have anything?
Each of them has a milling cutter for hard machining.
Just ask their application engineer. He should show you a milling cutter and test together with you.
I would say, they’re ready to make everything at the moment.
gruß Klaus
