587,313 active members*
3,348 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Milling machine yaw and pitch adjustment
Results 1 to 1 of 1
    Jan 2012
    I was hoping someone could give me some help with my Dore Westbury milling machine. I‘m not sure what the model number is though. (picture attached below)
    I have absolutely no experience with milling machines so am finding things very confusing.
    I need to be able to skim a fraction of material using a fly cutter.
    As I mill across the material (winding away from me) the cut my side of the spindle is deeper than the cut the other side.
    I have done a bit of research and I think the pitch of my machine is out?
    I can see how you would adjust the yaw (which seems fine) but I cannot see how you could adjust the pitch?
    Any help regarding this matter would be very much appreciated.
    Many thanks
    Richard
    Attached Thumbnails Attached Thumbnails $(KGrHqFHJDcE63Z(jjCLBO0o!bIsNQ~~60_12.jpg
  1. Fanuc 0iMC Buzzing sound - Machine adjustment
    By Leha_Blin in forum Fanuc
    Last Post: 02-21-2018, 11:48 PM
  2. Automating an existing manual adjustment on a machine
    By rando in forum RC Robotics and Autonomous Robots
    Last Post: 06-18-2010, 06:49 PM
  3. Machine pitch error compensation
    By sab in forum Uncategorised MetalWorking Machines
    Last Post: 04-21-2006, 05:52 PM
