603,872 active members*
3,651 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics Partner 1 set tool depth Z axis
Results 1 to 10 of 10
    Feb 2007
    6
    I am a new owner of a Milltronics Partner 1. I have everything hooked up and running. I use Bob-Cad to design and download my programs to the CNC mill. When I run my program I can set my X and Y axis but I am having trouble setting my Z depth for my tool height which ends up starting above my part approximately 1/2" above my part. I would appreciate any help I can get. Thankyou
    Nov 2013
    128
    Go to parameters, coordinates, check your g54 Z coordinate and make sure you don't have it set to anything other than zero. You may use that parameter to make global height adjustments, or for example if you have a sub program using g56 you may adjust for fixture height difference.
    Feb 2007
    6
    Re: Milltronics Partner 1 set tool depth Z axis
    Thankyou for your response Allen. I tried that and it made no difference. I even went as far as to put in a -.5" in the Z coordinate and it still made no difference.
    Feb 2007
    6
    I have the subset set to 0 as well. Would that have anything to do with it?
    Jun 2007
    98
    maybe obvious , but are you sure your are specifying a tool #
    what tool does the control think is in the spindle ?
    Feb 2007
    6
    I am specifying it as tool #1 then I entered the tool diameter. I can get it to work when i set the tool depth and then re-enter it .5" deeper and it works fine. I have not tried it with a tool change in the same program yet to see if the next tool starts .5" higher. I will have to try that, but i would like to get it set up properly.
    Jun 2007
    98
    X and Y are table coordinates , but Z is for tool lengths , so they have to be set for each tool . Does the readout display change when you enter the tool # and offset length?
    Try to MDI a P260=1 enter / cycle start this tells the control that tool #1 is active . By the way , if you are using a drill as the tool , the tool diameter really doesnt matter .
    Dia or CC ( cutter comp) is only a factor when using an end mill where the dia is comped
    Sep 2010
    537
    What does your program look like? It needs a T01 M06 G43 H1 line to call up tool #1 and activate the offset for tool #1, at the end of that tool you need to cancel the tool offset, a few ways to do that, either a G49, or you can call G32 (Z to tool change position), or your next tool call of M06 should cancel the current offset and go to the next one, but I don't like rely on that if you don't have another tool call at the end of the program your last tool might still be active.
    Feb 2007
    6
    First off I want to say thanks for the response. It is awesome to have a site such as CNC Zone for us beginners. Now, I think I may have figured it out. I went into Parm/Tool and added .5" to the tool length and that seemed to do the trick. It moved down to my to .1" above the part as needed. Now i am going to run a program with a tool change and see if it works then.
    Jul 2010
    548
    Hi Schmink. If you set the Z tool with the hand wheel it will "ask" you for the position. This will set the tool # and Z position for that tool #. ( should be zero at the top of the part) unless you are using a "touch off block)
    If you had to add .5" to the tool length, you did not set your tool length correctly or you have a Z offset in Z axis for the G5X coordinates.
    sportybob
  1. Milltronics, Partner IV 4
    By Brian FRF in forum Milltronics
    Last Post: 09-11-2021, 05:53 PM
  2. Milltronics Partner 1G
    By BilletCharlie in forum Milltronics
    Last Post: 07-11-2013, 04:21 AM
  3. Milltronics partner 10
    By tasj in forum CNC Machining Centers
    Last Post: 03-23-2010, 06:12 PM
  4. MILLTRONICS PARTNER Z AXIS
    By efmautoclutch in forum Want To Buy...Need help!
    Last Post: 07-01-2009, 04:23 AM
  5. Milltronics Partner
    By MSGMachine in forum Viper Servo drives
    Last Post: 06-03-2009, 02:22 AM
