587,082 active members*
2,610 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Milltronics Post Processor Needed
Results 1 to 6 of 6
    May 2006
    150
    Guys,
    Which of the Milltronics post processors is correct for a Centurion 6 mill? I'm using 2007 and I also have V21.
    I clicked on the 'mill only' tab of their website, but I see several SLS processors. I thought those were for a slant bed lathe.
    Why would there be a different post for English and Metric parts?
    I've called the BobCad tech support, but I'm waiting for them to call me back. I get the impression that they hire a calling service, which only relays a message.
    I need to get this setup and running. I need start making chips. After that, I'll start learning some more.
    Jan 2006
    4396
    Have you had any success editing your own Post Processor??
    If you show us a working G-Code Program with your control I'm sure we can help. Once you learn the basics of post processor editing it is pretty easy to edit for others.
    Cheers!!!!!!!!!!!
    Toby D.
    "Imagination and Memory are but one thing, but for divers considerations have divers names"
    Schwarzwald
    www.refractotech.com
    Jun 2007
    65
    But will bobcad work to make a lathe part.
    Jan 2006
    4396
    Yes it will. The only bug that I have found is with the Tool Nose Radius Compensation. Other than that it works.
    Toby D.
    Schwarzwald
    Oct 2005
    420
    Have any of you recieved your lathe manual in the mail yet? Not that it's a big deal. I have downloaded it from the website. More curiousity than anything else as they said it would be sent right out.
    ejdfast Guest
    Under mill only the centurian 6 sls is for the mill.
  1. GibbsCam Post Processor Needed
    By CCAJohn in forum GibbsCAM
    Last Post: 04-30-2024, 09:50 PM
  2. GibbsCam Post Processor Needed Help!
    By MetalZilla in forum Haas Mills
    Last Post: 06-03-2007, 04:11 PM
