603,912 active members*
3,367 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Milltronics "Z" axis erratic
    May 2010
    I have an older Milltronics Partner I. I was running parts for quite a while and after a cycle was about to finish, the "Z" axis started moving erratically up and down. It was enough to set off a servo alarm. I tried to reset and still same thing. I tried to power down and back up. During Home cycle same thing. Does anyone know what is going on with this machine?
    Jun 2007
    98
    Z servo problems
    You didn't mention how much it moves up/down .
    I had a problem with Z that could only be seen when I was indicating a part.
    Noticed that Z was "hunting" for a plane and going up/down +/- .015".
    I turned out to be accumulated carbon from the motor brushes was bridging across poles on the armature .
    Milltronics has a memo on this called " Cleaning tachometers on DC drive motors "
    It involves blocking up the head , removing the motor from the top of the column , disassembling the end cap of the motor and removing the brushes , then blowing out the dust .
    Not sure if this is really what your problem is though .
    Bob
  1. Replies: 2
    Last Post: 11-16-2012, 03:17 AM
  2. Thread Milling using "C" axis no "Y" on the machine
    By tejano4life72 in forum Mori Seiki lathes
    Last Post: 07-19-2010, 08:59 PM
  3. "Homing Milltronics Partner 4/Centurion 5"
    By RonRogers in forum Milltronics
    Last Post: 06-02-2010, 11:00 PM
