603,893 active members*
3,517 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Miltronic’s Partner 1 Spindle Orient Issue
Results 1 to 7 of 7
    Dec 2022
    7
    I have a Milltronics Partner 1 that will not start the spindle to turn for a Tool change , It will go to Orient and just stop the spindle will not turn . I did verify that the M27 and M28 will fire the plunger to lock the spindle. Is there a Mcode to jog the spindle to start the orient process? I do believe the Inverter should be triggered to go into jog mode .
    Rob
    Mar 2019
    58
    Re: Miltronic’s Partner 1 Spindle Orient Issue
    M18 or M19, I think its M19 should orient your spindle.
    Sent from my SM-N960U using Tapatalk
    Dec 2022
    7
    I just tried that and it doesn't try to rotate the spindle unless I hit CW for the spindle but then it just spins and does not shoot out the spindle lock.
    Mar 2019
    58
    Check your wires into the VFD. Some are pretty small and it sounds like its not getting the signal to jog when commanded to orient. Its a separate wire for jog than for fwd/rev if I remember correctly.
    Dec 2022
    7
    I will give that a try next . Thanks
    Dec 2022
    7
    I got the tools to change kind of it starts the orient process and the spindle lock shoots out. I see the spindle orient prox go on and off as the spindle rotates . I also see the output fired for the spindle lock cylinder on the diagnostic screen, The spindle does not seem to stop rotating. What else does it need see to finish the orient process.
    Mar 2019
    58
    Sounds like something mechanical is wrong. The cylinder should have a roller on the end that drops into a notch in the disk on the spindle. Make sure the roller is still there (I broke one once) and that the disk is not spinning on the spindle shaft.
  1. Torq Cut 22 - Spindle oscillates in M19 Spindle Orient mode
    By Monroe Design in forum Bridgeport / Hardinge Mills
    Last Post: 09-10-2021, 12:38 AM
  2. Replies: 3
    Last Post: 08-06-2018, 01:00 PM
  3. BridgePort VMC800 Spindle Orient Issue
    By StickShifter in forum Bridgeport / Hardinge Mills
    Last Post: 04-17-2016, 03:00 AM
  4. Fanuc 0M KIA VA-40 Spindle Orient issue
    By WICNC_85 in forum Fanuc
    Last Post: 11-11-2015, 08:49 PM
  5. Partner V - Spindle Issue / Repair
    By multiplex in forum Milltronics
    Last Post: 03-01-2013, 06:58 PM
