603,890 active members*
3,964 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > News Announcements > Mini-CNC machine tools and CNC machine tools-ray machine
    Aug 2009
    13
    Small CNC machine tools XK10, XK20, XK30, VMC420, CK20.Performance characteristics:
    01, the machine is powerful, easy to learn, wide range used, highly efficient and stability, cost-effective
    02, mature, high-performance Mach3 control system is based on Windows XP/Windows2000 installation with better performance, stylish and practical, you can manually direct the preparation of G code to complete the processing of your request, but also directly from graphic design to generate G code, graphic design software can MasterCAM, UG, CAXA such as post-processing software to generate G code; three-dimensional numerical control tool path to simulation experiment
    03, high-precision stepper motor drive system and high-precision ball screw
    04, the spindle motor is used the high-performance brushless DC motor, it is high efficiency, energy saving and environmental protection.
    05, orange color of the body, a strong mechanical representation, aesthetics generous
    06, hand / automatic operation, can manually controlled through the main control panel of the function of spindle
    07,the ideal size, electrical control system design and integration of human body design, also can be fixed with liquid crystal display, retractable tray length, 360-degree rotation. Provide a great convenience on operation. 08, low-cost high-performance machine is your best choice of teaching, DIY, families use etc.
    09, Safety and easy control, perfect oil circuit design
    10, the small machine is achieve to three-axis joint control (which can be increased to five-axis), can be hand / automatic e operation, safety and reliable; with linear interpolation, circular interpolation, MDI operation, dot operation, run automatically, dynamic display of processing, dynamic display of software. Procedures with the ISO basic functions to G code, and support to programming M and S code at the same time, to complete a complex model, automatically generated G code, simulation to the experiment, hands-on training in the use of CNC machine tools in the whole process, is the idea equipment of scientific research, teaching, DIY enthusiasts, especially technical institutions, training institutions. CNC milling and drilling the scope of materials as non-ferrous soft metals, composite materials such as plexiglass, electricity board, signs etc.
    shenzhen ginyu machine co.,ltd
    http://www.machine-mini.com/eng
    Attached Thumbnails Attached Thumbnails GXK30B小型数控钻铣床a.JPG   1111.JPG   GXK30A数控钻铣床.jpg
    mini small cnc milling machine vertical machining center
    ● High Grade Castings
    ● 3 Axis Taiwan Linear Guide Ways
    ● Siemens/GSK/KND Controller
    ● BT30 40 Spindle 8000RPM
    ● Pneumatic Cylinder
    ● External Manual Pulse Generator
    ● ATC 6-12 Tools
    ● Full Closed Cover
    ● Adjusting Pad Iron
    ● Lubricant System
    Mini CNC Vertical Machining Center
    (Processing/Educational Training)
    Machine Body Frame
    VMC330L VMC420L
    Products: Mini CNC Milling Machine Vertical Machining Center Machine Tools Conventional Universal Milling Machine CNC Lathe Radial Drilling Machine CNC Router and other CNC machinery
    If you have any needs, just feel free to contact us
    Eddie Liu
    Sales Manager
    Good CNC Machine Co., Ltd
    Add: No.455 Tengfei West RD, Tengzhou Shandong Pro. China
    Tel:0086.632.5555900 Fax:0086.632.5658466
    Mob:0086.18266092311
    E-mail: [email protected]
    MSN: [email protected]
    Skype:eddiecnc
  1. mitek machine tools
    By fsantos in forum Want To Buy...Need help!
    Last Post: 03-13-2009, 12:50 PM
  2. Toy Machine Tools
    By Free Citiz in forum Hobby Discussion
    Last Post: 12-15-2005, 08:50 AM
