603,383 active members*
3,492 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > mini lathe producing taper when turning. what could be wrong?
Results 1 to 7 of 7
    Aug 2007
    28
    Hi all:
    I have a 7x10 mini lathe.
    I am trying to use it to turn down a 6mm diameter drill rod to 5mm.
    So i chucked in the drill rod in the 3 jaw chuck and used the tail stock at the other end to prevent rod deflection.
    However when i turn down the rod, the end closer to the tailstock has a diameter greater than that at the chuck end.
    That means that the rod has been tapered.
    I am still a newbie at the mini lathe and right now am clueless as to what might be causing this tapering. i dont see any play in the carriage or cross slide.
    Help!!!
    raj
    Sep 2009
    55
    Align the tailstock--PITA. Search the web for Rollies Dad's Method. The Yahoo 7x10 and 7x12 mini-lathe groups have a wealth of info. Also look at http://www.gadgetbuilder.com/ for a good write up.
    Aug 2007
    28
    Thanks!. will read up on the tuning
    Aug 2005
    191
    A quick way to get it adjusted close (til you can tune it up properly) is to adjust the tail stock towards the operator one half the difference in diameters.
    Or you can cut and adjust the tail stock set over till the front and back diameters of the rod are the same.:idea:
    Aug 2007
    28
    yea, looks like i am not the only one running into this problem
    http://www.cnczone.com/forums/archiv...p/t-43400.html
    Nov 2007
    617
    I believe any on-the-fly adjustments done to the tailstock would best be done with a slightly larger diameter and softer material, so as to minimize any tool deflection.
    <a href="http://www.cnczone.com/forums/mini-lathe/82871-7-x-10-project-started.html" target="_blank">7X10 Lathe conversion</a>
    <a href="http://www.cnczone.com/forums/open-source-cnc-machine-designs/335846-cnc.html" target="_blank">Custom X-Carve router</a>
    <a href="http://www.linkedin.com/in/tooldesign" target="_blank">LinkedIn</a>
    Aug 2010
    The 7x10 was my first lathe and mine turned taper out-of-the-box as well. The tailstock on mine was WAY out. It does have adjustment screws but they are hard to find (covered up by that thick globbered-on paint).
    The lathe is also relatively flexible so when turning without the tailstock you'll have to compensate for workpiece flex as well as machine flex.
    It's a good machine to learn on because you'll have to focus on setup, setup, setup!! I suggest getting the follow and steady rests. They only fit 1" workpieces but you can go much larger if you are creative. I turned 3" by C-clamping a 1-2-3 block to the bed and putting the steady rest on top of it. Not pretty but worked great!
  1. Mini Lathe Z axis Cutting taper
    By ctk1 in forum Haas Mills
    Last Post: 06-12-2010, 03:40 PM
  2. Replies: 2
    Last Post: 01-20-2010, 02:31 AM
  3. Lathe turning unwanted taper
    By Hackman in forum Mini Lathe
    Last Post: 08-16-2009, 06:18 PM
  4. Turning Between Centers on a Mini-Lathe
    By Nelson_2008 in forum Mini Lathe
    Last Post: 04-07-2009, 07:12 PM
  5. Cnc Turning wood on a mini metal lathe
    By whiteriver in forum Mini Lathe
    Last Post: 03-09-2006, 12:42 AM
