603,943 active members*
3,625 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Mirroring a fixture offset on a CNC-88
    Jun 2008
    27
    I know this is possible on a Fanuc but with Fadal how do you mirror a fixture offset?? (using format 1)
    I tried..
    G10 L2 P1 X5.00 Y00
    E1
    M98P1002L1
    E0
    G51.1X0
    E1
    M98P1002L1
    G50.1
    M30
    When I do this the program gets mirrored not the actual fixture offset.
    When you press "DF" it displays a list of fixture offsets.
    Is this possible on this control?
    thx,
    Apr 2007
    64
    Yes you can mirror a fixture in Format 1. Here's a WARNING for you if you use mirror imaging on a Fadal!
    Do not start on the cursor line if you need to do a mid program start. You want to do the AU,### command so it reads the program from the beginning. If you were to start in the center of the program on a tool change for example and the control does not read the G51.1 it will run the program as unmirrored.
    The following is out of the manual:
    G51.1 Mirror Image This code activates the mirror image mode.
    The axes to be mirrored are identified in the same block with the G51.1 code.
    EXAMPLE: G51.1 X0 Only the X axis will be mirrored
    G51.1 X0 Z0 Both X and Z will be mirrored
    • No motion will result from a block containing the G51.1 code.
    • The mirror mode can be initiated from any position, but for all practical
    uses, it should be initiated from the zero position of the axis to be mirrored.
    This is especially true in absolute.
    • Absolute and incremental moves can be mirrored.
    • Use G50.1 to cancel the mirror mode.
    • When mirroring contouring moves, the climb cuts become conventional
    and vice-versa. The program may require the G41 codes to be changed
    to G42. This is something that a programmer must determine. Sometimes
    left handed cutters with M4 can be used with contouring moves
    that have been mirrored.
    EXAMPLE: G0 G90 E1 X0 Y0 Move to the zero position of the axis to be mirrored
    H1 Z.1 M7
    G51.1 X0 Y0 Mirror X and Y
    G1 Z-.25 F40.
    X1. Y0 Mirror image position X-1.0 Y0.0
    Y-1. Mirror image position X-1.0 Y1.0
    X0 Mirror image position X+0.0 Y1.0
    G50.1 Cancel Mirror image
  1. G54.2 DYNAMIC FIXTURE OFFSET
    By KBLANKE in forum Mori Seiki Mills
    Last Post: 06-16-2009, 03:40 PM
  2. how do you use the fixture offset funtion
    By cob in forum Mastercam
    Last Post: 11-19-2008, 06:48 AM
  3. Creating a Fixture Offset
    By robmints in forum Mastercam
    Last Post: 09-01-2008, 05:20 AM
  4. NX5 Fixture Offset
    By H234 in forum Uncategorised CAM Discussion
    Last Post: 03-27-2008, 02:12 PM
  5. WTH Corrupt fixture Offset!?
    By DareBee in forum Fadal
    Last Post: 07-15-2005, 03:11 PM
