588,483 active members*
4,952 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Mirroring Toolpath
Results 1 to 4 of 4
    Oct 2006
    16
    Mirroring Toolpath
    Is there a way to mirror a toolpath either in cam or Preditor editor in G code? V25
    Thank you!
    Sam
    Aug 2004
    55
    Re: Mirroring Toolpath
    One thing to note, if you mirror a toolpath the cut direction will be reversed. If that's not a problem one way I've mirrored g code is, use replace then replace all Ys with Y- the replace Y-- with Y.
    Mark.
    Aug 2004
    55
    Some more notes, if there are G02/03 moves you need to mirror IJ as well and I think you need to swap all G02s to 03s and 03s to 02s. Probably easier to mirror the geometry in BobCAD the more I think about it.
    Mark.
    Jan 2007
    1795
    in some control, the G50 associated with axis letter scaling the whole toolpath, likely G50 Y-1.0
  1. mirroring toolpaths in NX7
    By mcrider49 in forum UG NX
    Last Post: 02-03-2014, 10:03 PM
  2. Mirroring
    By dertsap in forum BobCad-Cam
    Last Post: 02-28-2013, 05:09 PM
  3. fanuc 6M Mirroring issue
    By 69owb in forum Fanuc
    Last Post: 03-09-2011, 05:03 AM
  4. Mirroring with Mach
    By Cairns in forum Tormach Personal CNC Mill
    Last Post: 02-18-2010, 09:50 AM
  5. Mirroring Parts
    By babinda01 in forum Uncategorised CAD Discussion
    Last Post: 09-08-2008, 07:02 PM
