587,733 active members*
3,176 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Missing Program Disk for CMC tape emulator
Results 1 to 18 of 18
Hybrid View
    Oct 2008
    78
    Greetings from East Texas
    I aquired a SM1 last week and been working on cleaning it up. It has a CMC dos base tape emulator but I did not get any books or disk with it. Could some point me to a copy of the CMC download software and a copy of the master file. I have not been able to power it up I think it's because the master is not loaded.
    Donnie
    Oct 2008
    78
    Could someone give the cable pin out seeing as they did not follow rs232 standards.
    Feb 2008
    48
    Tape Emulator Info
    Check out this site for the program and Manual.
    http://www.amtsinc.com/support/download.html
    Good luck
    Oct 2008
    78
    Thanks but I done try the file they had. Back in the 80’s every body did there own thing with “RS232 standard” So I need CMC software link and Cable to be sure. Now if someone has use the amtsinc software with a CMC card and it works then I have a different problem.
    May 2007
    64
    Here is CMC web site they should be able to help you
    http://www.cmcsystems.com/
    Rick
    Oct 2008
    42
    The AMTSINC software will work on the CMC emulator but the cabling is different, I will post the wiring tomorrow or you can call amts.
    ltr
    Oct 2008
    78
    That cabling info would be great
    Oct 2008
    42
    CMC BOARD
    PC (FEMALE 9 PIN) to CMC EMULATOR(MALE 9 PIN)
    2 - 6
    3 - 2
    4 - 7
    5 - 3 SHLD
    AMTS BOARD
    PC (FEMALE 9 PIN) to AMTS EMULATOR(FEMALE 9 PIN)
    2 - 3
    3 - 2
    4 - 4
    5 - 5 SHLD
    Oct 2008
    78
    Buddy1
    Thanks that did the job can now down load the master. Still have problems.
    Does any one have a schematics for a SM-1 with BX controller? Seams if I ground out pin 2 of IJ3 I can power up then if I press the operate button the drives will power up and I can move the drive by adjusting the balance. This is before I load the master. Once the master is loaded the drive power relay and all but the COR relay drop out. I’m left with the screen asking what language but no keys work.
    Oct 2008
    42
    The most common problem is that there is a key stuck. Bang on all keys and buttons about 5 times each and see if you cant select '0' for English. Let me know if this does not work
    Buddy1
    Oct 2008
    78
    Buddy
    My muilti meter tells me there is not a stuck switch.
    This machine been setting over two years.
    Donnie
    Oct 2008
    42
    If a key is not stuck then the problem will be either the scan clock on the MPU brd or the Front Panel brd has a bad mux chip. Do you have any spare boards?
    Buddy
    Oct 2008
    78
    No I have just what's in the rack.
  1. First part of uploaded program missing
    By quizzze in forum Fanuc
    Last Post: 10-24-2008, 07:23 PM
  2. tape emulator
    By bbrreid in forum DNC Problems and Solutions
    Last Post: 04-12-2007, 09:03 PM
  3. I need to build a paper tape emulator
    By paramax55 in forum CNC Machine Related Electronics
    Last Post: 04-11-2007, 10:40 PM
  4. Replies: 8
    Last Post: 04-09-2007, 06:58 PM
  5. TU48 Tape emulator (on PDP-11)
    By Nurglle in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-16-2005, 08:13 PM
