588,616 active members*
5,626 visitors online*
Results 1 to 7 of 7
    May 2004
    3
    Missing Steps with Laptop
    Hello,
    I am just starting out with CNC. I'm missing steps with turbocnc when I run it with my laptop computer. It works fine when I use my desktop.
    I've monkeyed around for hours with the all the motion parameters, but nothing seems to help.
    Any suggestions?
    Thanks,
    Al
    P.S. Here are some details:
    Computer: Acernote Light Pentium (ebay purchase $55)
    Operating System: Windows 95, restart to MS-DOS
    Driver: Geckodrive 210
    Stepper: 1st try: Vecta, 2nd try: Slosyn, same results
    Power source: 1st try: Regulated 28V with big capacitor, 2nd try: 18V batteries: same results.
    from turbocnc startup screen: mean latency 6.93 microsec, Max 59, max Hz 14422
    Mar 2003
    2139
    Many laptops don't work because the voltage at the parallel port is too low. The only fix is to try another laptop or go with a desktop machine. It's not turbocnc, it's a hardware issue.
    Eric
    I wish it wouldn't crash.
    Oct 2003
    175
    just came out from the laptop too ... i was toppin of with the laptop about 15 ipm i switched over to a 333 desktop and it runs smooth and now i start skipping at like 52 ipm oh the other thing is the laptop was connected to a dock station and i had the lpt mounted in it i also tried the port in the laptop itself but same effect skippy jumpy
    May 2004
    3
    Thanks,
    I just wanted to make sure that there wasn't some trick that would make my laptop work. Since none appeared, I bought a used desktop and it works like a charm. -Al
    Mar 2003
    779
    Are you running your laptop on batteries or on AC plug. A laptop will decrease power by up to 30% when on batteries just to make them last longer. To get full power from any laptop you must have it plugged into AC.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    May 2004
    3
    HomeCNC,
    I always run it with the adaptor plugged in. The battery is nearly dead and lasts only about 5 minutes without the adaptor. -Al
    Jun 2003
    1365
    I also run a laptop, I run a compaq pentium 166. I had problems missing steps during rapids because my rapids were turned up way high and the acceleration was way high too.
    I turned it down quite a bit and it works great now.
    Jon
  1. Replies: 7
    Last Post: 01-02-2005, 09:41 PM
  2. Output voltage on LPT port varies with OS on laptop?
    By Beezer in forum Computers / Desktops / Networking
    Last Post: 11-20-2004, 10:12 PM
  3. PC vs. Laptop
    By DAB_Design in forum Computers / Desktops / Networking
    Last Post: 07-26-2004, 02:04 PM
  4. Steps per inch formula, What I am doing wrong?
    By Noah in forum Gecko Drives
    Last Post: 05-28-2004, 12:56 AM
  5. Lost Steps How does it Happen?
    By High Seas in forum CNC Machine Related Electronics
    Last Post: 01-31-2004, 03:57 AM
