588,344 active members*
5,557 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > EDM Discussion General Topics > Mitsubishi DWC 110G Wire EDM Wiring Installation Assistance Needed
    Oct 2009
    7
    As the title says need help with wiring installation.
    Here is my situation. My building is located in an light industrial area and with some welders located on my power line the three phase power is not clean enough for cnc equipment. I have three mills all on phase converters and do not have any problem with them now. I purchased an older Mitsubishi DWC 110 G wire EDM. Going to also hook it up to a phase converter. Will go with a 10hp phase converter (Almost twice size needed).
    My problem, cannot find an electrician that can figure out how or more specifically where to connect the wiring to my EDM. I will feed a transformer that came with the machine with my phase converter, with an output on transformer of 220V, which is what the book calls for. However, we cannot find where to hook up line from transformer to the EDM. There is a power box that is connected to machine, but it appears to be another transformer to feel electronics? So where are the bars to attach the three phase to the EDM? Secondly the book calls for single phase 110 also. Is that a seperate line that needs to feed the electronics or is that pulling off the three phase.
    Hoping for some help here, before we have to start pulling off panels to find a place to hook the wiring up. No other EDM's in my area so odds of finding electrician with knowledge of EDM's isn't going to happen. Would appreciate any help that anyone here could offer. Once we determine where to look, they will figure it our, just need a starting point. Thanks
    Jan 2009
    64
    Not sure if this helps but we have CX-20s and they have one thick cable coming from the transformer directly into a metal box of approx. 3"wide x3"deep x5" tall and about 12" from the floor, left side of the CX and this houses a large trip switch with connectors.
    Dec 2006
    131
    on most machines you hook up the incoming to the main disconnect. Your machine should break the 220V 3 phase down to 110v single on its own. Be very carefull with using a phase converter. It is a big no no to hook an EDM to a phase converter unless it is a digital phase converter. You can burn out the power supply if the power doesnt stay matched. I know of a few shops running rotary phase converters with no issues and then a few others have learned the hard way that if the converter drops voltage on one leg it can cost alot of money fast. They cost alot compared to a rotary but phase perfect digitals will give you cleaner power than what you can get from most power companys.
  1. Mitsubishi Wire EDM
    By Roswell28 in forum EDM Discussion General Topics
    Last Post: 01-08-2022, 02:47 PM
  2. Wire EDM Mitsubishi DWC-200 H1
    By Roswell28 in forum Waterjet General Topics
    Last Post: 03-10-2014, 05:44 PM
  3. Mitsubishi, DWC-110G Wire EDM
    By professor in forum Waterjet General Topics
    Last Post: 03-02-2008, 09:56 PM
  4. Camsoft Installation help needed...
    By Darc in forum CamSoft Products
    Last Post: 10-17-2004, 01:24 PM
