587,523 active members*
3,831 visitors online*
Results 1 to 5 of 5
    Aug 2013
    13
    Mitsubishi M64 serial communication !!
    I'm currently working on repairing a box-moving robot, which uses a CNC Mitsubishi Meldas M64 to control it's movements.
    As I've seen around here, my initial problem was quite typical. The Lithium backup battery went down, and therefore a large number of programs and parameters was lost.
    I spent three days in learning how to back-up the remaining data, formatting, and reinstalling everything via RS232 serial communication. (I used the Hercules software, a regular multi-communications one).
    My problem is this:
    While making the above mentioned operations (format, backup,etc.) I used the original configuration for IN/OUT devices: Port 0, Device:0 (Both in Outputting and Inputing data).
    Then, I accidentaly changed the port number to 2. Since then, It was impossible for me to establish communication again.
    Whenever I try to set the port to 0 again, I get the code: "E02 - Data Over", meaning I'm trying to set an out-of-range parameter.
    Does anybody know how to reset the port back to 0?
    Do I need to format everything again?
    The problem is, that if I choose to format and the ports remain at 2, then I'll be no longer able to load the programs again...
    Thanks in advance for taking the time to read my post.
    Regards
    Martín
    Jan 2011
    350
    Do you have floppy disk for your control?
    Aug 2013
    13
    No, I don't. The control does not use floppys. Only it's own RAM cassette.
    May 2008
    107
    @marcunni24: You have to change the port in Setting menu, not in another one.
    Aug 2013
    13
    Quote Originally Posted by Namnp2007 View Post
    Thanks for your reply.
    I've tried changing it in the Settings menu, and in the Input / Output menues as well. I couldn't do it in neither of them. I always get the same reply: "E02 - Data OVer".
    Could it be the selection switchs (CS1, CS2) in the communication boards?
    I've got an HR211 in/out expansion board. I don't know what else to try.
    I tried resetting the base parameters, but it dind't worked.
    I'd appreciate any comments on this regard. Thanks
  1. Serial communication problem
    By marcunni24 in forum Computers / Desktops / Networking
    Last Post: 08-08-2013, 03:46 AM
  2. serial communication to tl-1
    By gkmotzart in forum Haas Lathes
    Last Post: 09-29-2012, 05:47 PM
  3. Serial communication
    By Limpan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-25-2011, 05:17 PM
  4. 8025 GP,M,MS serial communication
    By midnightrambler in forum Fagor Automation
    Last Post: 04-23-2009, 06:10 AM
  5. Maho 700 serial communication
    By breazr in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-08-2008, 06:59 PM
