603,310 active members*
2,649 visitors online*
    Feb 2014
    3
    Mitutoyo Touch probe 902329
    I bought this guy on Ebay thinking I could figure it out. I can't find any documentation on it anywhere. It only has two wires connected although the connector has four pins. I thought that that kind of setup would be a normally open or normally closed switch but that does not seem to be the case. Unless this thing is broken. Are there active circuits that only use two wires? If anyone could help me out I would sure appreciate it. I did see another thread with this probe and I left a post there but I was hoping the community could give me a hand.
    Bart
    Dec 2009
    522
    Quote Originally Posted by Densoman View Post
    Bart
    Super old post. This is a conductive probe. Pin 1 goes to the probe tip and pin 3 goes to the shank (or vice versa). I have a new one in the box. Thought I would bring closure to this one in case anyone searches for it again.
    Would make a dandy easy touch probe.
  1. Mitutoyo touch signal probe
    By bertcnc in forum Digitizing and Laser Digitizing
    Last Post: 05-01-2020, 04:37 PM
  2. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  3. cnc touch probe
    By shawnc515 in forum Uncategorised MetalWorking Machines
    Last Post: 09-30-2010, 11:10 PM
  4. using a mitutoyo mtp1 signal probe
    By bfreedland in forum Digitizing and Laser Digitizing
    Last Post: 09-07-2007, 05:28 PM
