603,308 active members*
3,264 visitors online*
Results 1 to 9 of 9
    Oct 2006
    78
    Mitutoyo touch signal probe
    Hi all,
    can anyone please help with connection data --pin outs / operating voltage--anything?
    for a mitutoyo touch signal probe no.902329
    Thanks bert
    Jun 2005
    14
    mtp1 probe info
    for wiring, with the probe tip facing down, and the connector facing you, the upper left and bottom right pins are an NC switch. the remaining two pins are for the led.
    Dec 2008
    3
    Question I have the same probe but I think a different socket
    Quote Originally Posted by bfreedland View Post
    Uhhh...
    Hmmm.. my probe doesn't have an upper left / lower right...
    it has a sort of upside down 'Y" shaped socket, see below...
    (ignore the hyphen characters "-", used as spacers)
    up (shaft)
    ---O-
    ---O-
    -O- -O-
    down (probe)
    any ideas...????
    Thanks in advance
    john
    (flame2)
    Sep 2004
    4
    If you are still looking for information, I have a PDF of the original manual.
    I can tell you that it's a conductive probe, which means that the circuit is closed by a signal passing thru the tip to a conductive item which you are probing, back thru the frame of the machine, etc.
    On the DIN plug connector (end of the cable not plugged into the probe), P1 and P3 are used, P2 and P4 are not used. P1 connects to the shank of the probe, P1 connects to its tip. When the tip couches the work piece it therefore closes the circuit between P1/P3.
    Let me know if you want a copy of the manual.
    Carl
    Oct 2006
    78
    Thanks for the info Carl. I would like a copy of the manual. Can you post the pdf. here or send me a copy.. [email protected].
    Bert
    Dec 2008
    3
    Yes please the PDF manual
    Have been in calif for a while & just got back...
    Yes please email the PDF manual
    you can direct it to: [email protected]
    Feb 2014
    3
    Re: Mitutoyo touch signal probe
    I see this is a pretty old post but I have one of those Mitutoyo touch signal Probes too. I can't figure it out. It only has 2 wires and it is not a simple NC or NO switch unless it is broken. I got it off EBAY and it looks perfect. If any of you guys has any info I would greatly appreciate it.
    Bart
    Sep 2015
    11
    Hi Carl,
    I got a similar Mitutoyo touch probe (902431). I don't finde any information, please send me the .pdf manual, thank you very much. My email: [email protected]
    Elek
    Nov 2006
    Looking also, If I get a version I will hopefully host a link.
  1. Renishaw MP-10 Probe, Start Signal
    By mflux_gamblej in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2025, 10:52 PM
  2. Replies: 12
    Last Post: 06-05-2013, 06:05 PM
  3. Probe signal loss with USB pendant?
    By revwarguy in forum Mach Software (ArtSoft software)
    Last Post: 02-01-2010, 11:17 PM
  4. using a mitutoyo mtp1 signal probe
    By bfreedland in forum Digitizing and Laser Digitizing
    Last Post: 09-07-2007, 05:28 PM
  5. Macro for a probe signal
    By mcash3000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-11-2006, 07:04 PM
