603,308 active members*
2,863 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Modernization of the Elm Dc Servo Controller (Russian UHU by Hudognik)
Page 3 of 15 1234513
Results 41 to 60 of 284
  1. #41
    Jun 2008
    66
    Show ScreenSet with error message. Connect - USB or RS-232? And on what scheme is collected converter?
    + http://translate.google.com/translate_t#
  2. #42
    Apr 2006
    56
    Появляется сообщение можете не читать, потому что некоторые символы отсутствуют, возможно, потому, что я еще не загружена поддержка для русского языка.
    Я использовал RS-232, и работа с Windows XP.
  3. #43
    Apr 2006
    56
    Dobrý jozefp,
    Vidím, že na fóre, hovoríme chvíľu?
    Vďaka
  4. #44
    Jun 2008
    66
    You Write, in english - we not one here. To whom that this can be useful. In Private Messages possible and in russian.
    Installation of support of the russian language - will not help. You have no relationship with servocontroller. Answer my questions in message #41.
  5. #45
    Apr 2006
    56
    sorry for message #42 and 43,
    I try to connect servo with RS-232 interface, according to last version of scheme and hex files according to thread #1 and #15.
  6. #46
    Jun 2008
    66
    Connect RS232/UART to sevocontroller. Connect as on figure external led and resistor. Give power. When striking the button "Подключить" (Connect) led must once On/Off (flash). If You have no flashings, that check the number COM port. And correctness of the montage RS232/UART. If led blinks (1 once), that check the chain from output RS232/UART before conclusion 2 and 3 AtMega88 (DIP).
    You are a Fuse-bits have programmed? If yes, that try here is so.
  7. #47
    Apr 2006
    56
    I will do this scheme and I try.
    I have AVR Studio 4.15 and AVRISP MK2 USB programmer and this is images of fuse settings. I observe that fuse settings is sett from hex files.
  8. #48
    Jun 2008
    66
    I have no programmer AVRISP II so picture to show can not. But beside You exactly are wrong installed Fuse-bits. This 100%!
    Try so.
  9. #49
    Apr 2006
    56
    Tanks arisov77,
    I will try to change fuse settings, .elf files is a file with saved fuse settings.
    Many many many......... tanks for you help and to patience for me.
  10. #50
    Nov 2005
    3
    Hello arisov77,
    Is it possible to post the source code of servotuning.exe ?
    thx,
    dleung.
  11. #51
    Jun 2008
    66
    The Author servotuning.exe on contact does not go.:nono:
  12. #52
    Nov 2005
    3
    Question
    It's too sad to hear the author does not release source codes.
    How about asking him to make an English version for us ?
    arisov77,
    your effort is really appreciated.
  13. #53
    Apr 2006
    169
    Quote Originally Posted by dleung View Post
    arisov77,
    the program is encrypted i v try to convert the gui to English (chair)(chair)(chair)(chair)
  14. #54
    Jun 2008
    66
    I have no coordinates of the author Alexander A. Karsakbayev.
    Except ScreenSet http://www.cnczone.com/forums/showpo...7&postcount=15
    nothing while help can not.
    Today in Google has found this http://www.panoramio.com/photo/8432307 . Possible after my address - he call back.
  15. #55
    Apr 2007
    21
    Dear Friends,
    Here's the English Release of ServoTuning.exe , i did it without permission from author since there's no reply from him. But i hope this helps many people who want to try, since i did not build up board i'm not sure if there's else translation exists in dialogs.
    It will be perfect if another friend share an english documentation for :
    * Latest HEX (EEP file too in some cases) and Fuse Settings
    * PCB and Layout (Various AVR Processors)
    * ServoTuning software guide
    Best Regards,
    Ozan
    Attached Files Attached Files
  16. #56
    Jun 2008
    66
    Thank you, friend!
    I have already checked - all work!
  17. #57
    Apr 2006
    169
    Ozan is awesome
  18. #58
    Jun 2008
    66
    Small remark
  19. #59
    Mar 2007
    215
    Wow, nice work ozan....
    I have yet to build this version but have built the original Elmchan ....
    Anyone know if this works with the original? I'm too lazy to test it right now....
    I think there are many people who will be very happy with your work...
    Thanks very much ...
    Michael
  20. #60
    Apr 2006
    56
    Hi arisov77,
    I blowup my first atmega88, (I hope to be first and last), now I read with PonyProg2000 and other programmer second atmega88 and is OK, but I do not courage to write controller because, for me, is not very clearly how to programmer atmega88 yet.
    So, first write Servo AtMega88 CompInt Modif .hex
    second write Servo AtMega88 CompInt Modif .eep
    and last setting fuse bits as in the image of post #46 ???
    Tank you very much.
  1. Russian UHU by Hudognik
    By myown in forum UHU Servo Controllers
    Last Post: 12-18-2018, 06:33 AM
  2. New advanced CNC controllers for modernization
    By Jonne in forum News Announcements
    Last Post: 02-11-2011, 12:41 AM
  3. modernization Fanuc system 5
    By pardoel piet in forum Fanuc
    Last Post: 12-12-2010, 02:43 PM
  4. NC-controller for modernization only 850$!!!
    Last Post: 12-15-2009, 11:47 AM
