603,348 active members*
2,759 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > Modernization of the Elm Dc Servo Controller (Russian UHU by Hudognik)
Page 9 of 15 7891011
Results 161 to 180 of 284
  1. #161
    Apr 2006
    56
    jvolk,
    Thanks for you advice, I'll make changes, and I'll try again.
    ''That's weird..'' I know, but why?, I d' not.
    Tanks again.
    Moraru.
  2. #162
    Sep 2009
    10
    Okay... change this when you will have time and report if there will be some success.
  3. #163
    Sep 2009
    10
    Is anyone interested in my PCBs? I will send drawings to manufacturer, so I can order some PCBs for you. I don't know price yet, but I guess that will be around 10 €.
  4. #164
    Jun 2008
    66
    Jvolk, congratulate!
    Moraru, install in chain of the signal Reset external Brown-out Detection, for instance МС34064 ( http://www.microsemi.com/datasheets/mc34064.pdf ) or similar. This must help with zeroizing EEPROM. See the scheme.
  5. #165
    Apr 2006
    56
    Hi arisov77,
    Tanks for you advices, I'll make all changes and I try again.
    Do you make any progress with new project?
    Moraru.
  6. #166
    Jun 2008
    66
    Quote Originally Posted by moraru View Post
    …Do you make any progress with new project?...
    In connection with big utilised capacity on the main work, the work on new variant servocontroller I have temporarily stopped.
  7. #167
    Sep 2009
    10
    moraru, how did you set Brown-out Detection on microcontroller?
  8. #168
    Jun 2008
    66
    On my experience turned out to be that AtMega8 more subject to malfunction EEPROM, than AtMega48 or AtMega88. For AtMega8 better to install external Brown-out Detection.
  9. #169
    Apr 2006
    56
    Quote Originally Posted by jvolk View Post
    Brown-out Detection is disable.(post #47 in this thread).
  10. #170
    Jun 2008
    66
    Brown-out Detection (BODLEVEL) it is necessary enabled!
    I this shown on picture in post №48.
    I do not know that in earl BODLEVEL in JTAGICE mkII (beside me such no). But it is necessary to install maximum importance of the voltage Reset.
  11. #171
    May 2006
    2415
    I will second using BOD, I am running the original Elm configuration and it used to do nasty things to the tuning parameters every now and then at power off without BOD, set it and never had another problem, machine been running at least a year without incident since then.
    Cheers.
    Russell.
  12. #172
    Nov 2008
    5
    Smile
    Thanks Arisov77, u the man.
  13. #173
    Nov 2008
    5
    Can i have the *.asm source code of Servo_Mg48_20Mhz_v3_5 ..?
  14. #174
    Jun 2008
    66
    Quote Originally Posted by alex7street47 View Post
    Here it is ... with comments in Russian.
    Attached Files Attached Files
  15. #175
    Sep 2009
    10
    Is there any suggestions or instructions how to set parameters?
  16. #176
    Jul 2007
    7
    Thank you JVOLK.
  17. #177
    Sep 2009
    Hello everyone!
    I'm having some problems with jvolk's servo boards. I have ordered PCB's that he had made and populated one board. For a moment everything worked and I was able to control the motor using the servo-tune program. After a while I wasn't able to make a connection between my computer and the servo controller. I also soldered only the MAX232, Atmega88, 7805 and the necessary capacitors, resistors and connectors on a second PCB and I still haven't been able to make a connection. When I connect the programmer I am able to read and program the chip, I have also checked all the connections and voltages and everything seems so be fine.
    Does anyone have an idea what could be the problem with my servo controllers?
    Best regards,
    Primoz
  18. #178
    Apr 2006
    85
    hello all
    i have also make elm servo with tiny2313 and ir2104and irf540. i have a problem in testing. some time eeprom earsed on power failer.
    please tell me how can i put the velues of p0 to p6 in my code permanently?
    thanks
    shabbir mughal
    [email protected]
  19. #179
    Apr 2009
    3
    Red face
    Hello everyone,
    I build the driver that you have developed, but I would like to know what the latest version of the driver software, and the last scheme.
    I have looked at previous post, but there are many, and I explain no.
    Forgive my English, I use the google translator .
    Thank you very much for such good work, greetings.
  20. #180
    Oct 2005
    3
    Great work
    i do that, after 5 burning ir2184 and irfp260 I start my driver !
    So I propose to show video driver in work!
    {My english is too slow} )
  1. Russian UHU by Hudognik
    By myown in forum UHU Servo Controllers
    Last Post: 12-18-2018, 06:33 AM
  2. New advanced CNC controllers for modernization
    By Jonne in forum News Announcements
    Last Post: 02-11-2011, 12:41 AM
  3. modernization Fanuc system 5
    By pardoel piet in forum Fanuc
    Last Post: 12-12-2010, 02:43 PM
  4. NC-controller for modernization only 850$!!!
    Last Post: 12-15-2009, 11:47 AM
