603,970 active members*
2,969 visitors online*
IndustryArena Forum > CAM Software > GibbsCAM > modify move origin
    Nov 2005
    244
    modify move origin
    Is it possible to use the - Modify move part origin - command picking the lines of the automatic work piece? What is the easiest way to move the origin to the corner of the stock being machined?
    I can use it for picking the actual part, holding down the alt key and getting the distance.
    Jun 2006
    56
    Normally, I will dimension the point I want to move to in all dim (x,y,z) then enter all three into the Move Origin box.
    Might not be the best way, but its the best I've found. If anyone has a better way, would love to hear it too.
    Jun 2003
    513
    Quote Originally Posted by camtd View Post
    Move Part Origin dialog box -> click appropriate field (X,Y,Z) -> Alt + mouse click side of stock you want origin to move to -> repeat as required for other sides -> Do It
    The origin will move to those points.
  1. Stock Origin
    By stang5197 in forum Mastercam
    Last Post: 03-13-2007, 05:36 PM
  2. Origin and mazak??
    By Fendertok in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-13-2006, 01:06 AM
  3. Point of origin.
    By MonkeyKong at d in forum Mastercam
    Last Post: 07-04-2006, 06:40 PM
  4. Move part origin
    By vertcnc in forum Solidworks
    Last Post: 11-06-2005, 09:15 PM
  5. Origin trouble
    By JOE65 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 02-15-2004, 06:57 AM
