Hi all,
I need someone to modify my MPOST for vertical machine center w SIEMENS 840 de 4 axis rotary table A.
Or anyone have this post.
Thank you all in advance
bassam
Hi all,
bassam
I have a Siemens post for the Fadal.. Let me know if you still need it.....
Than you very much for your kind reply.
Yes, I need the post please........... FADAL . Could please send ? & also Can you make some modification If i need?
Tanks in adavnce
Bassam
I may be able to do that. Let me know what kind of machine is it for and what modifications you are needing...
Charlie
1- Machine Vertical machine center(x=+/-410, Y=+/-305, Z=610 mm) rotary table A axe(range only 0to +359.999 - dia 255mm) the work piece is on X- .
2-Controller : SIEMENS SINUMERIK 840 DE / MMC103 NCU 573.2 SW4.3 .
3-ususally I use a post SIE810(Mpost) in 3 axes with some modification, for more complex I need 4 -5 axes (A axe range 0 to + 359.999 shortest path) + repostion macro. & NO need for Tool change.
The most important thing I need is A axe will always output in range between 0 + 359.999 & also when rotary axe A reach to limit I need the tool to be plunge in +z rotate A axe to other position & continue machining.
Please if you need any other information ,let me know my e mail : [email protected]
Thank you in advance
Bassam
I looked through my list of Post files and I have a 3 axis post for the Siemens 840D control.
I can send it to you, if I need to re-write it for a 4 or 5 axis machine, I would have to charge you for my time..
Please send me an IM with your email address and let me know...
Thanks,
Machinster...
Dear Machinster,
Thank you very much. I ask you kindly to send the 3 post files for siemens 840, I will get the best & to suite my controller sw ver. .
then i will discuss with you your charges.but Can you make all the modifications which i sent them to you, & how much will cost me please?
Bassam
Dear Machinster,
my e mail is : [email protected]
Please let me know how well this Post Processor works for you... Thanks
Dear machinster,
Thank you, Here is a sample nc file;
%END12
G90 G40 G17
S796M3
G54
G0X12.72Y0.
Z25.M9
Z2.5
G1Z-2.F162.34
Y188.4F324.68
G3X9.48Y188.4I-1.62J0.
G1Y0.
G3X12.72Y0.I1.62J0.
G1X15.72
Y188.4
G3X6.48Y188.4I-4.62J0.
G1Y0.
G3X15.72Y0.I4.62J0.
G1X12.72
Z-4.F162.34
G0Z25.
M9
M30
plaese note that I need a post for siemens840de 4-5 axis with rotary table A axe range 0 up to (+)359.999 & anable to call a macrio when it is out range.
Thank you
Dear Machinster,
Could you please send me the post processors for the SIEMENS840DE.
Bassam,
I did send you a 3-axis post processor for the Siemens 840D... Did this post processor work for you? I do not currently have a 4 axis post processor for the Siemens 840D but I could probably modify one for you if I knew more about your machine.
I need to know what your rotary axis is, which side of the table left or right, picture would help. Which direction is Positive A, which direction is Negative A. Inverse time feed rate, G93 yes/no and maybe some more information if it is a 5 axis.
Maybe contact me at my email address.
I cannot guarantee that I can help you, but remember you will always get what you pay for....
Thanks,
The Machinster and his minions.....
