603,899 active members*
2,192 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Modifying a post
    Apr 2003
    57
    Modifying a post
    I would like to add a canned text line on my tool parameters in V9.1. The help says to modify the post txt file but I am not sure how the txt relates to the PST file. I am trying to add a line that says "retract" and will insert a "M25" line which works with my machine. Thanks,
    We are open 24hrs. - just not in a row.
    Mar 2006
    1013
    Sounds like the Retract is a function of some other movement. It should probably be done in the machining function.
    But... if you open the .txt file, you'll see the other Canned Text functions. You can also do a search. Just format it the same as the others.
    Mike Mattera
    Tips For Manufacturing Training CD's, DVD's for Mastercam, SolidWorks, Inventor, G-Code Training & More
    http://www.tipsforcadcam.com
  1. Modifying Post Processor For my needs.
    By blakemachine in forum Post Processors for MC
    Last Post: 08-21-2009, 05:56 AM
  2. Need a little help with modifying my post .
    By hall6ppc in forum Mastercam
    Last Post: 07-30-2009, 05:33 PM
  3. Modifying a post processor
    By CJH in forum ArtCam Pro
    Last Post: 03-27-2009, 03:30 AM
  4. Modifying 4th axis post
    By weirdharold in forum Post Processors for MC
    Last Post: 02-16-2009, 04:53 PM
