603,981 active members*
2,873 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Momentary push button as limit wsitces?
    Jan 2016
    10
    Hello
    I own the Gecko G540 controller, and wondering about limit switches- i have a 3 axis CNC machine with limit switches (they actually installed a momentary push button- N/O)- while i see everywhere limit switches connected as N/C.
    how can I connect NO switches to the gecko drive? will use Mach 3 or Mach 4 to operate the system
    Jan 2005
    1943
    Re: Momentary push button as limit wsitces?
    You just invert the pin in the mach3 software. Machine 3 doesn't care if you use NO or NC switches, it just has to be set to know if an open or closed circuit means you are on the limit
    Sent from my Z958 using Tapatalk
  1. Momentary Button OEM Code
    By DrivenMachines in forum Mach Wizards, Macros, & Addons
    Last Post: 04-22-2016, 04:31 AM
  2. Push Button Start Stop
    By jakemestre in forum Benchtop Machines
    Last Post: 04-12-2013, 12:57 AM
  3. Quick adjustment at the push of a button
    By igus in forum News Announcements
    Last Post: 05-10-2011, 03:05 PM
  4. Where to find push-button oil hole valves?
    By Claven2 in forum Mini Lathe
    Last Post: 04-17-2008, 03:01 PM
  5. Need Simple Push Button Controller
    By edo in forum Stepper Motors / Drives
    Last Post: 02-02-2007, 11:32 PM
