588,338 active members*
4,845 visitors online*
Thread: monel 400
Results 1 to 9 of 9
    Sep 2009
    21
    monel 400
    How is tapping monel 400... 6-32 .500 dp.?
    Should i use oil, spray mist .
    i'll be tapping 10 pcs manually
    Sep 2005
    281
    monel 400
    I would use a good oil and go big as possible with the minor diameter, I would also roll tap if you can. the high nickel content in monel makes it tough to machine. good luck
    Sep 2009
    21
    thanks it should be fun. no extra's.
    Sep 2005
    281
    To bad you dont have a bar end to try, I remember years ago we were tapping 0-80 in almost pure nickel on a mill, a old timer would grind the heal off a cut tap, right behind the cutting edge leaving about .01/.02 land of the cutting edge, this way there is no draging of the rest of the tap that would seize to the material, it worked, once again good luck.
    Jan 2007
    1389
    I would rather die LOL
    seriously its not that bad, however there is a monel 400 and a monel 405, off hand I forget which one is harder to machine, I wanna says its the 400 and its a pain in the butt compared to the 405.
    I never tried a roll tap but have used cut taps make sure you get a good quality one that is COATED. I think there the same ones that are used inconel. In my opinion inconel 718 cuts and taps better than monel.
    Use oil it works better than coolant and if your threads are tight tols. use one rgh tap then run a new tap(finish tap) in there as after a few parts it tends to put in burrs and undersizes the thread root. I noticed that the rougher generally wears really fast on high threads per inch the coarser ones are not that bad.
    Jul 2005
    12177
    I saw the thread title and thought; "give it to someone else to do".
    A good high sulfur tapping fluid is needed, and lots of luck.
    Oct 2010
    Monel 400 is nickel copper alloy which becomes more hard in cooling... It is mostly used in marine applications & it also has excellent resistance. Main thing is that is becomes harden cool temperature.
    Mar 2008
    443
    Through hole or blind hole? What class of thread is required and how is the depth being gaged?
    That's a VERY deep thread for a #6-32 in a material that tough.
    Jun 2010
    26
    Form tap, don't cut. Any tapping fluid or even WD-40 will be fine. You only need to worry about using high-sulfur fluids for cutting.
    pearls ain't free
  1. suggestion, feed,speed,DOC on hastaloy,monel and 316
    By ambrose in forum MetalWork Discussion
    Last Post: 11-19-2007, 04:13 PM
  2. Monel
    By Delw in forum Composites, Exotic Metals etc
    Last Post: 05-30-2007, 09:48 PM
  3. Monel 400
    By bala955 in forum MetalWork Discussion
    Last Post: 05-03-2007, 11:20 AM
