587,523 active members*
3,753 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Monitor has problems on start up
Results 1 to 4 of 4
    Oct 2012
    64
    Turned on my rw15 for the first time in a few months and this is what the screen looks like. Cent 7 controller
    Attached Thumbnails Attached Thumbnails 41C33AE8-D81D-417C-9476-F453810A3083.jpg
    Oct 2012
    64
    Re: Monitor has problems on start up
    I was able to get the monitor to start correctly, ran all after noon no problem. Restarted this morning, same problem. Had to restart 5+ times to get the monitor to start correctly.Will call Milltronics on Tuesday
    Jul 2010
    548
    Your CMOS battery on the mother board is about to die.
    Give me a call
    952-288-6340
    sportybob
    Oct 2012
    64
    Thanks Bob, thru trial and error I figured it out.
    The monitor would start correctly on the 7th time the machine was started, each time the pattern on the monitor was different always starting on the 7th try. I assume it was going thru the all the different monitor profiles since the cmos batt was dead, with the 7th one being correct for my monitor . New 2032 on the mother board solved my problem.
    I did a screen shot on every page in Bios before batt swap, pretty straight forward after that
  1. Monitor problems need a resistor value
    By aussco in forum Dynapath
    Last Post: 02-03-2021, 03:30 PM
  2. Replies: 0
    Last Post: 10-29-2016, 08:11 AM
  3. Fadal VMC20 Monitor Problems
    By WeTDrEaM in forum Fadal
    Last Post: 07-13-2013, 04:48 AM
  4. V2XT Monitor problems
    By ba5634 in forum Benchtop Machines
    Last Post: 03-21-2008, 06:34 PM
  5. MONITOR PROBLEMS
    By metx in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-20-2007, 03:23 AM
