Hi All,
does anyone actually monitor air flow while there plasma torch is cutting. The cutting charts for the Hypertherm Duramx torch give air flow in their cutting charts.
This actually makes sense to me because it really is the amount of air flowing through the nozzle which is of importance. You could have the correct pressure and zero air flow theoretically speaking.
Poor quality cuts can also be as a result of a "lazy flame" due to insufficient air flow (I'm not going to say air pressure) so it would be reassuring to know this parameter is correct.
Does anyone know a low cost means of measuring up to 500 SCFH (235 SLPM) at typical compressed air pressures of up to 120 psi.
Thanks, Keith.
