603,314 active members*
2,154 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Morbidelli Author 504 - Xilog Plus
    Dec 2015
    Hi everyone!
    First of all, I want to apologize if this thread is now in the forum, but i have not found it.
    I have a Morbidelli Author 504 with Xilog 3.
    I do my "line" draws in Autocad or Sketchup, then I export it to DXF and import this DXF to Xilog Plus in order to obtain a PGM file of the draw. (I cant open dxf from xilog 3 directly)
    Im able to do this kind of jobs:
    The black lines are the zones where the drill has passed.
    I want to do this job now, but I dont know if it is possible with that machine (Morbidelli Author 504):
    I want to do the inverse process too, but knowing the first one is the same.
    So my question is:
    Can I do that kind of job (relief) with my machine? If yes, How could I do it using AutoCAD or Sketchup? (Regions, 3D objects, Faces...?)
    Have a nice day and thanks in advance.
    Sorry for my english.
    Service SCM BR Guest
    Re: Morbidelli Author 504 - Xilog Plus
    Hi friend, yes is possibile make conversion of the Autocad DXF2000 for Xilog. But only Line, Arc, Circle and Polyline.
    Via iPhone of the Tapatalk
  1. Morbidelli Author 503
    By num1040 in forum CNC Machining Centers
    Last Post: 07-22-2018, 10:49 AM
  2. Morbidelli Author 427
    By elktw in forum CNC Machining Centers
    Last Post: 08-14-2015, 07:40 AM
  3. Morbidelli Author 430
    By Scooby Doo in forum Commercial CNC Wood Routers
    Last Post: 04-27-2012, 02:32 PM
  4. Morbidelli Author 636 top
    By mwatkinson in forum Commercial CNC Wood Routers
    Last Post: 05-11-2010, 10:52 PM
  5. morbidelli author 504
    By msahin2012 in forum Commercial CNC Wood Routers
    Last Post: 05-19-2009, 01:06 PM
