586,036 active members*
3,603 visitors online*
Results 1 to 4 of 4
    Dec 2018
    Question Morbidelli U26
    Hello,
    I owned a Morbidelli U26 1990 model router and today when I turned-on the machine its displayed me an error in Italian PLC Blocco. I don't know what that means because the language that i was using the Morbidelli was English and it changed to Italian. Can anyone knows how to change the language back and also how to fix the problem?
    Thank you,
    Mike.
    Quote Originally Posted by Mike_deme View Post
    Hello,
    Thank you,
    Mike.
    Hello. This message means the PLC is blocked.
    Sometimes its enough to log inte the hidden parameters, the section where it lets you set the clock. There is a menu button wich enables or disables the PLC system providing there is nothing else mailfuntioning in your machine, such as a broken pressure valve or something that needs repair causing the plc to stop working. Do you have access to the hidden passwords required?
    Hope this helps. Best wishes
    Sep 2022
    Re: Morbidelli U26
    Salve mi trovo anch'io con la mia u 26 con il blocco del plc, mi da errore a linea:1 e istruzione non corretta. Qualcuno può aiutarmi grazie.
    Jun 2023
    Re: Morbidelli U46
    Hi
    We have morbidelli u46 that have been shut off for about half a year. As a result the battery died and thus it lost its PLC. I've been searching everywhere for the backup disk but it seems lost. So as the title states i'm looking for the PLC for a morbidelli u46.
    Any help or tips is much appreciated.
    Regards
  1. MORBIDELLI U50
    By Baldo in forum WoodWorking Topics
    Last Post: 07-14-2021, 03:09 PM
  2. morbidelli
    By bashir40 in forum WoodWorking Topics
    Last Post: 03-20-2014, 09:57 AM
  3. morbidelli
    Last Post: 03-20-2014, 09:52 AM
  4. morbidelli 503
    By henry kleyn in forum Australia, New Zealand Club House
    Last Post: 02-09-2013, 04:43 AM
  5. Morbidelli U15
    By hayabusa in forum Machinery Manuals / Brochures
    Last Post: 11-06-2012, 12:41 AM
