Yeah, maybe so, I've had nothing to compare it to, just what I was experiencing with what I have, the machine is serial #26 or near there. Maybe the newer motors are better?
Cool, now I have a Goal to exceed, more than 3in3 min.
The motor cooling system is really working well. Its an electric 600cfm fan on top of the motor with an intake duct out the top of the enclosure. This way the air is cool and dry to keep the motor and housing clean.
The thermostat sensor is down inside the grease hole for the bearings at the PTO end. This is as buried as it can get away from any external heat influence. Running under load it will slowly climb to 125 F where the fan kicks on, in about 15 minutes the temp is back down to 100 F, so the duct, fan, shroud system is for sure pulling the heat out of the motor.
The fan motor wires shared the same conduit as the motor wires for convenience, But I did discover that when the fan turned on that the 60hz 110v caused the motor to drop 6hz and vary slightly in rpm, since putting the fan wires with the coolant chain the motor runs without a hiccup now.
I also have the load meter hooked up now, with the cutting shown above it is only pulling 2.8 amps.
The spindle bearings are running relatively cool for doing 6400 rpm for a few hours straight. Due to the Kluber grease I'm sure. It's giving me confidence to raise the rpm. Did some more engineering and if I change the gearing to 1:1.5 I can get 9600 spindle rpm without maxing out the motor and the belt and pulley speeds are still well within their limits. Running at 6400 the pulleys stabilize at 125F, the belt is good for 185F
Bumped the feed slider up to 150% on feed rate, so 54 ipm on the same cut, below is the load meter barely registering, was showing 4.8 amps peak on the VFD monitor. VFD is set for 16 amps max output for the motor but the load meter scale is set at 180% right now. Works out to about 2.55 cu in min, getting there. According to Destiny tool this cut should be done at 80 ipm! for almost .007 chip load or 3.78 cu in min
https://youtu.be/IDayTyo90ao
It looks like it will come down to the limits of the steppers torque to push the cutter fast enough to tax the motor and not loose steps. That and get the rpm up higher! That is an easy experiment, I think I'll get the pulleys ordered.
jh
