Z Column stiffness is the first weakness. I measured the flex - see pics, and improved the column stiffness with a back plate over the cut out weak point.
More power without matching rigidity is likely to result in rapid cutter breakdown.
This is not the only machine weak point - it is a light mill. So don't expect massive improvements from this mod.
Keen
