Top of the morning to ya ladies and gentlemen!!!!!!!!
Couple of quick questions for those successful and knowledgale in using mach3. I need to reverse my x and y axis motors and can't find the software setting to do that. It use to be listed under config in mach2 but low and behold, it is no longer there for version 3. What is the preferred method of reversing the motors. I'm using an encoder interace board so just switching wires may interfere with some of that!! Any suggestions????
Also, second question!!! I'm using a charge pump and want to disable the g320's. Can I wire the 3 position relay to apply 5 volts to the err/res terminal thus activate when the charge pump is active and to put a ground on the terminal when not active. I can't think of a reason why it wouldn't work this way. But, again, I'm just learning!
Have a wonderful day!
billyjack
:cheers:
