587,726 active members*
3,569 visitors online*
    Aug 2011
    Mori DL-20 dual spindle lathe problem.
    I have a Mori Seiki DL-20 lathe with a Fanuc OTT control on it. I'm getting an
    "EX457 R-spindle drive unit alarm" on head 2. There is an AL-15 alarm on the drive in the cabinet. Anyone have any advice on what to do to get it cleared and the machine running?
    Feb 2009
    6028
    If, and a big if, i remember correctly, AL15 is a switching circuit abnormal. Could be, high/low spindle winding contactor set, probably labeled KM200/KM201, Auxiliary contact on the contactor set ( thats where the 24 volt signal goes through to the I/O board detecting high/low), or a bad Idec/Izumi 24VDC power supply that feeds the switching contactors.
  1. Bridgeport EZ-Path Lathe Spindle problem..
    By jdocmm in forum DNC Problems and Solutions
    Last Post: 12-11-2011, 12:38 AM
  2. mori seki yasnak 2000g tl-2 spindle problem
    By sixty8frbrd in forum Mori Seiki Mills
    Last Post: 06-08-2011, 06:21 PM
  3. miyano dual spindle lathe
    By terrywinstr in forum Community Club House
    Last Post: 02-09-2009, 02:14 AM
  4. Dual Z axis and Dual Spindle
    By Adamj12b in forum Mach Software (ArtSoft software)
    Last Post: 08-28-2008, 09:15 PM
  5. mori seiki mill with a spindle problem
    By imwllc in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2005, 12:31 AM
