587,481 active members*
3,201 visitors online*
    Feb 2010
    Mori MV35 240V 3 Phase
    Does anyone know the correct hookup for the 3 phase power to the terminals inside the cabinet? One fuse has blown twice in 3 days. I need to know which terminal the 240V leg of the 3 phase hooks to?
    Feb 2009
    6028
    As per Mori instalation manual, all legs must be 5% of each other or better. If all legs are good, please specify what fuses are blowing.
    Jan 2009
    44
    I have 2 Mori TV -30's. I was told to put it on L2, the middle leg on both machines. That is what they call the wild leg. You just have to make sure that leg doesn't run straight to the control and your fine. It should run to a transformer first.
  1. Mori MV35/Fanuc 6M
    By SteveY in forum Mori Seiki Mills
    Last Post: 07-01-2010, 11:34 PM
  2. 160V DC 12 Amps from 240V AC single phase supply
    By ftkalcevic in forum CNC Machine Related Electronics
    Last Post: 04-27-2010, 05:07 AM
  3. Mori running on 240v RPC - voltage sensitive?
    By damae in forum Mori Seiki lathes
    Last Post: 11-20-2009, 07:03 PM
  4. Wiring Slo-Syn 240V 1 Phase Motors
    By PerPlexed in forum Servo Motors / Drives
    Last Post: 06-17-2009, 04:24 AM
  5. spindle belts for mori seiki mv35/40
    By brandou10l in forum Uncategorised MetalWorking Machines
    Last Post: 01-06-2008, 12:59 PM
