587,999 active members*
5,305 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori NT-1000 SZM-Disengage BW head for tool change?
Results 1 to 6 of 6
    Dec 2009
    100
    I'm about to program a part which, due to its length, requires being held in both the main and the sub spindles. A built-in safety feature in the machine will not allow a tool change with the part held in the BW head. Is there any reason I can't park the BW head while the tool change is taking place, then re-acquire the part? Is there a chip blow-off feature that will clean any chips off the part and the collet before re-clamping? Thanks for any help.
    Feb 2009
    6028
    I assume you mean sub spindle by BW?
    Look in the back of your ladder diagram. All the Mcodes are in there including second chuck air blow. I also believe there is a interlock release Mcode to allow the tool change while sub is engaged.
    Dec 2009
    100
    Yes.
    Found it.
    Haven't found it, yet, but may not need it.
    Thanks.
    Jun 2008
    372
    There must be an interlock for this as our NT1000 will do a toolchange with the part gripped in the chuck as long as the A axis is at -128 or 0
    Dec 2009
    100
    Thank you. I'll try that.
    Dec 2009
    100
    Yes, it will do the TC with the sub spindle clamped as long as A is 0 or -128. The issue is getting it to work with the sub spindle closer to the main spindle. Otherwise we'd have to extend the stock way out of the main spindle by several inches, and that defeats the purpose of supporting it with both chucks.
  1. Mori MT2000 tool change macro
    By Green Button in forum Mori Seiki lathes
    Last Post: 05-10-2022, 06:09 AM
  2. BP VMC 1000/22 - Tool Loading and Change
    By shaffin in forum Bridgeport / Hardinge Mills
    Last Post: 08-09-2012, 05:14 AM
  3. Best tool change head?
    By 777funk in forum DIY CNC Router Table Machines
    Last Post: 04-09-2011, 02:44 AM
  4. Arrow 1000 tool change problem!
    By Jelle_b_k in forum Cincinnati CNC
    Last Post: 02-24-2011, 07:00 AM
  5. tool change head
    By DrStein99 in forum MetalWork Discussion
    Last Post: 08-20-2007, 03:37 PM
