587,714 active members*
4,637 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > MORI SEIKI MILL PARTS SOLENOID VALVES wanted
Results 1 to 5 of 5
Hybrid View
    May 2018
    27
    looking for Lucifer Valve for a SV500 mill part number E121F44
    10W
    and other mori seiki parts i can't think of if you have parts please post here or PM thanks a lot
    Jan 2005
    15362
    Re: MORI SEIKI MILL PARTS SOLENOID VALVES wanted
    Quote Originally Posted by LUCIFERNIETZSCH View Post
    10W
    It does not have to be a Mori Seiki part, any solenoid valve will work you just have to find the same voltage coil an Watts, what you have looks like 100v 10w so may be harder to find 110v may work
    Parker sell Lucifer valves
    Mactec54
    May 2018
    27
    oh cool thanks. so which is more important the Wattage part or the voltage? ? i have found some 9W and 5W 2 Way valves on ebay too
    Jan 2005
    15362
    Voltage has to match the solenoid coil supply that your machine is using, you would also want the watts to be close also, this would depend though on the circuit wiring and if the circuit is protected by a fuse if you go higher the fuse would have to be rated for what you are using I would not go lower than the 9w
    Mactec54
    May 2018
    27
    thanks 9W worked
    LUCIFER
    i believe in Lucifer and i think that's why it worked
  1. Mori Seiki SL1 Retrofit Hydraulic Solenoid Wiring
    By ObsidianLabs in forum Mori Seiki lathes
    Last Post: 01-06-2020, 07:24 PM
  2. Wanted: Mori-seiki ZL-15 Operator Manual
    By Shepster in forum Machinery Manuals / Brochures
    Last Post: 08-09-2016, 02:13 PM
  3. Good source for inexpensive solenoid valves?
    By fuper in forum Hobby Discussion
    Last Post: 12-11-2010, 03:52 AM
  4. Inexpensive Solenoid Valves
    By greenchair in forum RC Robotics and Autonomous Robots
    Last Post: 09-23-2008, 02:59 PM
