588,529 active members*
6,519 visitors online*
Results 1 to 5 of 5
    Jun 2007
    4
    mori-seiki TL1 Fanuc 6T parameters
    i need a manual with the parameters for my mori-seki TL1 fanuc 6T
    the params was errased 1 month ago
    please help mi
    Oct 2006
    100
    Did you locate your parameters ? What type of spindle drive do you have ?
    Jun 2009
    8
    I am also looking for manuals for a mori Seiki TL1 twin turret machine with Fanuc 6T controls.
    Ours doesn´t finsih booting up. Display shows Error 901 (turret 1).
    Don´t know if this is a Mori Seiki error code or Fanuc error code.
    According to the Fanuc error codes, 900..... are related to Bubble memory problems.
    Anybody got any ideas ? ? ?
    Best Regards
    Ian England.
    Jun 2009
    11
    Ian,
    Your Bubble Memory could be dead. I recommend you using a Bubble Memory replacement made by Memex in Canada. They have a way to automatically download all parameters from your original board. I'm not sure if this would work when you already have a System Error such as Alarm 901.
    It seems you are located in Argentina, you can find more information in spanish in the following link:
    http://www.cncsoluciones.com/Ampliacion6.htm
    Jun 2009
    8
    Thanks for the link.
    I will give them a call to see if they can help.
    Meanwhile I would still like to track down a full set of manuals for this machine, as it was bought second hand and arrived without ANY documentation whatsoever ! ! !
    Best Regards
    Ian England
  1. Mori Seiki SL-20 Fanuc 10T
    By premier_industr in forum Fanuc
    Last Post: 12-15-2009, 02:55 PM
  2. MAPPS Parameters for a Mori Seiki NL
    By tminnig in forum Fanuc
    Last Post: 09-30-2008, 10:57 PM
  3. Replies: 3
    Last Post: 07-13-2007, 04:42 PM
  4. mori seiki nf 20dt parameters.
    By PRIOR666 in forum Fanuc
    Last Post: 06-04-2007, 04:07 PM
