Happy Monday!
Our Mori went down last week with the High parity Error. We followed to book in regards to fixing the problem (resetting parameters and whatnot) and that seemed to fix things. Everything seems to be working except for the spindle. It will spin, but the wrong direction (from whatever button is pushed) and at around 10rpm. From what I read this sounds like it could be thinking it needs to change gears or index or something along those lines. I'm not totally sure on which route to go for finding that problem. I am going through our manuals for it right now.
The other confusion is in the parameters itself. I have a section of parameters that are written in by hand. Those are the parameters that gave me the above results. The confusing part is that there is also a "stock" parameter setting page in my manuals. Some of these values differ from my record sheet. Not only these but there are some other parameters (sequence parameter and Timer) settings that I for the life of me can't find where I could change these on the control.
If anyone could point me in the right direction, that would rock. I am going to sit here a bit and try to get a grasp on the manuals here. Any thoughts or ideas are very much appreciated. Even if someone knows of someone that has the same setup, that would help too. Or if anyone knows of a Midwest (NW burbs Illinois) mori seiki place that might have this info. Thanks for the help!
Andrew
ps I called Mori, they said they had no records of that machine. They told me to call Fanuc. I talked to a helpful guy there who had records of that machine, but no specific parameters or anything for me. I figured that would be the case, but figured it couldn't hurt to try and call all the places.
