good day to all, I am working on a machine with fagor 8055 plus-m control on the table brings motionmaster and in the tool changer kosakura bought the second-hand machine but does not bring any information; in the installation all well the problem to start the operation axes x, y, z work well the problem is that the spindle does not turn check the fagor module and everything is fine send me signal to the drive that is a magnetek GPD 515 but not remote it marks me frequently so it does not rotate, but in manual mode if the spindle rotates; someone who knows that I may be failing; I appreciate all the possible help and I do tests in manual mode and it works well but in the changes of speed I would have to be adjusting the frequency.
regards
