Why not set it to 2.5A, the max supported by the board? You might be able to do 3 if you add a fan.
A 6 wire in the half coil mode has the same spec as unipolar.
I forget which motor you are using.
yea thats why i was thinking about switching to the 4wire motors
Your 6 wire motor is rated at 3 amps unipolar. Half coil rating is also 3 amps.
